Announcements
Mirror object transforms?
dg3duy
dg3duy
I want to make a mirror of an object and when I manipulate it I also see the transformations reflected in the copy of the object. Here in this example it only works as a mirror when I manipulate it on a single X axis.
I am totally confused in understanding the operation of matrix3 when using it to generate a copy.
The example code is thanks to DenisT
 	delete objects
 	origin = box pos:[-30, 10, 10] wirecolor:yellow
 	rotate origin (eulerangles 0 0 45)
 	mirrorX = copy origin wirecolor:green
 	tm = origin.transform * (matrix3 [-1,0,0] [0,1,0] [0,0,1] [0,0,0])
 	mirrorX.transform = prescale tm [-1,1,1]
denisT.MaxDoctor
i guess you want a different effect... try this:
 	delete objects
 	rotate origin (eulerangles 0 45 45)
 	mirrorX.transform = origin.transform * (matrix3 [-1,0,0] [0,1,0] [0,0,1] [0,0,0])
 	resetscale mirrorX
dg3duy
Unbelievable! Thank you!
