Messagebox contents don't fit
I'm writing a simple script, part of which is to check whether all materials are properly named. The ones that are not should come out as a message. I'm putting them in a multiline string and displaying later in a messagebox. However the messagebox gets incorrectly sized and some of the text simply doesn't fit! What am I doing wrong? The code is below:
fn CheckBadNames =
BadMaterials = #()
BadMatList = ""
for mat in scenematerials do
if (matchpattern mat.name pattern:"*material*") then
append BadMaterials mat
append BadMatList (mat.name + "\n")
if BadMaterials.count > 0 then
BadMatMessage = "These materials have bad names:\n" + BadMatList + "You better rename them before archiving"
messagebox BadMatMessage
And attached is the screenshot of how it looks in the end...
miauuuu
Which version of 3ds Max you use?
In 3ds max 2014 there is no problem with the size of the messagebox. Please see the image.
https://miauu-maxscript.com/
3dsmax 2018 latest update. Could it also be operating system-specific? I'm on Win7.
loliojohn87
Community Visitor
Community Visitor
Conduct extensive research to produce Content Writing precise, knowledgeable, and informative information. Use credible sources to support the claims you make.
