Mesh Cleaner max script
elpie89
elpie89
Hi, I'm trying to find a way to access the  Mesh Cleaner from maxscript
in particular the function behind the following button
How do i access it ?
Thanks in advance
MartinBeh
You can use showProperties (MeshCleaner()) to see the properties (checkboxes and results).
And Changsoo just reminded me of the showInterfaces command which you can also use on an instance of MeshCleaner:
showinterfaces (meshcleaner())
  Interface: meshCleanerInterface
   Properties:
   Methods:
    <void>ValidateMesh()
    <void>RepairMesh()
   Actions:
OK
Note that you will have to select the object with the modifier, and you will have to switch to the Modify tab before running any of those.
PS: And you probably have to convert the object to editable_poly before applying the MeshClean modifier...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
