Animate edit poly modifier verts
danlane3d
danlane3d
How do animate verts in an editpoly modifier with maxscript? My current attempt doesn't set keys even if I set the modifier to animate mode and also wrap it all within an on animate context.
Here's my code so far, it matches the vert positions of one object to another but I'd like it to animate the verts:
sourceobj = selection[1]
modifyObject = selection[2]
storedVertPositions = #()
vertCount = polyop.getNumVerts sourceobj
print vertCount
				-- Cache vertex positions in world space
				for i = 1 to vertCount do (
					pos = polyop.getVert sourceobj i
					--append storedVertPositions #(i, pos)
					append storedVertPositions pos
				-- add epoly to modified mesh
				ePolyMod = undefined --Edit_Poly ()
				for modify in modifyObject.modifiers where modify.name == "Edit Poly" do ePolyMod =  modify
				select modifyObject
				max modify mode
				modPanel.setCurrentObject ePolyMod
				ePolyMod.enabled = true
				subobjectLevel = 1
				ePolyMod.useSoftSel = off
				ePolyMod.SetSelection #Vertex #{}
				ePolyMod.animationMode = true
					sourcePos = storedVertPositions[i]
				currentPos = polyop.getVert modifyObject i
				diffVector = sourcePos - currentPos
				with animate on(
					at time 100
						modifyObject.modifiers[#Edit_Poly].Select #Vertex #{i}
						modifyObject.modifiers[#Edit_Poly].MoveSelection diffVector
						modifyObject.modifiers[#Edit_Poly].Commit()
						modifyObject.modifiers[#Edit_Poly].SetSelection #Vertex #{}
Thanks for reading 🙂
Cheers
A娘
for modifier animation, you should use slidertime instead of at time
and you should use setvert method instead of what you did
danlane3d
Thanks, I'll give that a try.
danlane3d
I don't think there is a setvert method in the edit poly modifier.
A娘
of course it has , you can't get all interfaces from maxscript reference , just show modifier , and you can see what methods it has
danlane3d
Well of course 😄
Thanks for the tip, I'll inspect it's methods.
