MaxStart, Custom User Path via MaxScript
Greetings
Past versions of 3ds Max particularly Max 2014/16, I've been able to set the MaxStart Custom User Path via a simple maxscript, example below. The script adds a custom directory to the 3dsmax.ini file, so the next time you start Max it launches the maxstart.max file in that location.
setINISetting (getMAXIniFile()) "Directories" "MaxStart" "c:\test"
Problems arise with the script in Max 2019. The script runs perfectly and updates the 3dsmax.ini with the appropriate custom path. However when you launch max again the 3dsmax.ini resets the MaxStart directory to the default ./scenes directory.
Only way I can get a custom path to stick is via the menus, how ever in this scenario I need it to work via maxscript.
Any help would be appreciated.
miauuuu
Try with this:
	--	CHANGE USER PATHS
	local projectFolderPath  =  "D:\\"
	pathConfig.setCurrentProjectFolder projectFolderPath
	local fontsPath  =  "F:\\3dsMaxVersions\\3dsMax_2018\\3ds Max 2018\\fonts"
	SetDir #font fontsPath
	local scenesPath = "C:\\Program Files\\Autodesk\\3ds Max 2018\\scripts\\Startup\\3dsMax_scenes\\scenes"
	SetDir #scene scenesPath
	local importPath  =  " D:\\3dsMax_scenes\\import"
	SetDir #import  importPath
	local exportPath =  "D:\\3dsMax_scenes\\export"
	SetDir #export  exportPath
	local helpPath =  "F:\\3dsMaxVersions\\3dsMax_2018\\3ds Max 2018\\help"
	SetDir #help  helpPath
	local previewsPath =  "D:\\3dsMax_scenes\\previews"
	SetDir #preview previewsPath
	local imagesPath =  "D:\\3dsMax_scenes\\sceneassets\\images"
	SetDir #image imagesPath
	local soundsPath =  "D:\\3dsMax_scenes\\sceneassets\\sounds"
	SetDir #sound soundsPath
	local plugCFGPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\en-US\\plugcfg"
	SetDir #plugcfg plugCFGPath
	local maxStartPath =  "D:\\3dsMax_scenes\\scenes"
	SetDir #maxstart maxStartPath
	local videoPostPath =  "D:\\3dsMax_scenes\\vpost"
	SetDir #vpost videoPostPath
	local heidiDriversPath =  "F:\\3dsMaxVersions\\3dsMax_2018\\3ds Max 2018\\drivers"
	SetDir #drivers heidiDriversPath
	local autoBackupPath =  "D:\\3dsMax_scenes\\autoback"
	SetDir #autoback autoBackupPath
	local materialsPath =  "D:\\3dsMax_scenes\\materiallibraries"
	SetDir #matlib materialsPath
	local _scriptsPath =  "F:\\3dsMaxVersions\\3dsMax_2018\\3ds Max 2018\\scripts"
	SetDir #scripts _scriptsPath
	local startupScriptsPath =  "F:\\3dsMaxVersions\\3dsMax_2018\\3ds Max 2018\\scripts\\startup"
	SetDir #startupScripts startupScriptsPath
	local defaultsPath =  "F:\\3dsMaxVersions\\3dsMax_2018\\3ds Max 2018\\en-US\\defaults\\MAX"
	SetDir #defaults defaultsPath
	local renderPresetsPath =  "C:\\Program Files\\Autodesk\\3ds Max 2018\\scripts\\Startup\\3dsMax_scenes\\renderpresets"
	SetDir #renderPresets renderPresetsPath
	local renderOutputPath =  "D:\\3dsMax_scenes\\renderoutput"
	SetDir #renderoutput  renderOutputPath
	local animationsPath =  "D:\\3dsMax_scenes\\sceneassets\\animations"
	SetDir #animations animationsPath
	local archivesPath =  "D:\\3dsMax_scenes\\archives"
	SetDir #archives archivesPath
	local photometricPath =  "C:\\Program Files\\Autodesk\\3ds Max 2018\\scripts\\Startup\\3dsMax_scenes\\photometric"
	SetDir #photometric photometricPath
	local renderAssetsPath =  "D:\\3dsMax_scenes\\sceneassets\\renderassets"
	SetDir #renderassets renderAssetsPath
	local additionalScriptsPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\scripts"
	SetDir #userScripts additionalScriptsPath
	local additionalMacrosPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\usermacros"
	SetDir #userMacros additionalMacrosPath
	local additionalStartupScriptsPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\scripts\\startup"
	SetDir #userStartupScripts additionalStartupScriptsPath
	local tempPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\temp"
	SetDir #temp tempPath
	local additionalIconsPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\usericons"
	SetDir #userIcons additionalIconsPath
	local maxDataPath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\"
	SetDir #maxData maxDataPath
	local downloadsPath =  "D:\\3dsMax_scenes\\downloads"
	SetDir #downloads downloadsPath
	local bitmapProxiesPath =  "D:\\3dsMax_scenes\\proxies"
	SetDir #proxies bitmapProxiesPath
	local pageFilePath =  "C:\\Users\\YOU USER NAME\\AppData\\Local\\Autodesk\\3dsMax\\2018 - 64bit\\ENU\\temp"
	SetDir #pageFile pageFilePath
https://miauu-maxscript.com/
Brilliant, thanks miauuuu that did the trick.
