MAXscript/Toolbar Issue
I have a MAXscript I'm trying to install at my new job. I have multiple buttons within the toolbar and it was able to run fine at my last workplace. Now,  I'm able to run it and created a toolbar for it, but when I click on any one of the buttons, nothing is dropping in. It's driving me crazy. Has anyone had this issue and knows how to fix it?
Thanks in advance,
Hana
kevinvandecar
Hi Hana,
well I am not sure you have given us enough information. There are a couple of possibilities, probably relating to files that are not being found? I assume you are creating the toolbar manually from the CUI... but even that is a bit unclear from your post. Usually once you create the toolbar, you would drag the actions (typically defined by a macroscript) into buttons. If the macroscript actions, are pointing to the macscript files you want to run, then 3ds Max has to be able to find them, or have a full path to them. 3ds Max will search the some locations when a path is not provided. See this topic for fileIn executing of scripts, and how it searches for them:
http://help.autodesk.com/view/3DSMAX/2018/ENU/?guid=__files_GUID_86D82FCE_B88F_4487_9B34_B6222EDA1C7...
hope it helps,
kevin
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
