Announcements
Maxscript to Create layers from a .txt file
aliX8TFZ
aliX8TFZ
Hai there.,
How can i programmatically create layers., whose names are listed in a text file?
Every time i use some scripts to clean my scene all the objects will be merged to " 0 default " layer ., so i need to make layer structure again. I will create a text file with the list of layers i want to make. And i can give the path of file to crate layers with same names.
Im just a biginner of Maxscript . So please help me. Thank you
Swordslayer
Simple flat layer structure?
	local file = openFile @"C:\folder\file.txt"
	while not EOF file do LayerManager.newLayerFromName (readLine file)
	close file
aliX8TFZ
thanks for the quick solution
aliX8TFZ
i went to your script page., Good works., Keep going👍
