Announcements
MaxScript String Formatting?
deven.saxenaP7BD5
deven.saxenaP7BD5
I am looking to access an external python file that is located in the documents folder for windows.
The file that I wanna access "C:\Users\USERNAME\Documents\MaxScripts\mainUi\launch.py"
I don't want to hardcode the Username so instead, I found this "sysInfo.username" that spits out the user name for the login.
So to add that in the string I can do something like this in Python:
"C:\Users\{}\Documents\MaxScripts\mainUi\launch.py".format(sysInfo.username)
What would be the equivalent to this in Maxscript? Or is there a better alternative to what I am trying to achieve?
Actual code that I wanna run:
python.ExecuteFile @"C:\Users\USERNAME\Documents\MaxScripts\mainUi\launch.py"
P.S. I will be linking this "python.Execute" to a button.
denisT.MaxDoctor
The simple way is:
@"C:\Users\" + sysInfo.username + @"\Documents\MaxScripts\mainUi\launch.py"
There are several other ways, but in this case I recommend sticking to the simple
deven.saxenaP7BD5
Hi Denis,
I tried doing that but it looks like Python.ExecuteFile gets stuck at "C:\Users\" and treats it as a file and fails. Looks like it wants a single String to execute.
-- MAXScript MacroScript Error Exception:
-- Runtime error: Failed to open file C:\Users\Failed to open file C:\Users\
-- MAXScript callstack:
--	thread data: threadID:6908
--	[stack level: 0]
--	In codeblock macroScript: DragAndDrop_Macro77; filename: C:\Users\USERNAME\AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU\usermacros\DragAndDrop-Macro77.mcr; position: 97; line: 4
--		Locals:
--		Externals:
--	[stack level: 1]
--	called from top-level
I also tried storing the file name as a variable and executing the variable instead of the string but no luck.
filePath = "C:\Users\" + sysInfo.username + "\Documents\MaxScripts\mainUi\launch.py"
python.ExecuteFile @"%" (filePath)
denisT.MaxDoctor
filePath = @"C:\Users\" + sysInfo.username + @"\Documents\MaxScripts\mainUi\launch.py"
python.ExecuteFile filePath
deven.saxenaP7BD5
Awesome I knew I was close. Thanks, Denis for your help.
