Maxscript + Qt close event
Message 1 of 13
I'm using code found here to load Qt UIs with maxscript:
https://forums.autodesk.com/t5/3ds-max-programming/maxscript-qt-ui/m-p/10052536/highlight/false#M268...
But I can't find how to trigger actions when the UI closes.
I'd like to achieve what "on rollout close" do with maxscript rollouts.
Thanks for your help.
Replies (12)
Message 2 of 13
Swordslayer
Override its closeEvent method:
	local py = python.import "builtins"
	local shiboken = python.import "shiboken2"
	local QtWidgets = python.import "PySide2.QtWidgets"
	local GetQMaxMainWindow = (python.import "qtmax").GetQMaxMainWindow
	if isProperty ::testDialog #close and shiboken.isValid testDialog and testDialog.isVisible() do testDialog.close()
	global testDialog = QtWidgets.QDialog(GetQMaxMainWindow())
	testDialog.mousePressEvent = fn mousePressEvent evnt = py.print (py.str.format "dialog click at {}" (evnt.pos()))
	testDialog.setWindowTitle "Pyside Qt Window"
	testDialog.setFixedSize 250 250
	testDialog.nativeCloseEvent = testDialog.closeEvent
	testDialog.closeEvent = fn customCloseEvent evnt = (py.print "custom code"; testDialog.nativeCloseEvent evnt)
	testDialog.show()
Message 3 of 13
Nice!! Thank you very much, I try that asap!
Message 4 of 13
denisT.MaxDoctor
Now you understand? How easy it works when the question is asked well and in the right place. 😉
Message 5 of 13
Just tried to apply it to the Qt UI loading code, but doesn't work 😢
I must miss something...
here it is:
	local QtCore = (python.import "PySide2.QtCore")
	local QFile = QtCore.QFile
	local QUiLoader = (python.import "PySide2.QtUiTools").QUiLoader
	local ui_file = QFile "test.ui"
	ui_file.open QFile.ReadOnly
	testDialog = (QUiLoader()).load ui_file (GetQMaxMainWindow())
	ui_file.close()
	testDialog.show()
Message 6 of 13
Swordslayer
Creating the widgets via PySide2 creates QWidgetWrapper that redirects all the calls to the python method if there's one, the widgets created via QUiLoader are not wrapped, they're created by Qt not by the python wrapper, so if you want to keep everything as is, you'd have to promote and register it as a custom widget in the designer first. Or you can make a python wrapper QObject that loads the ui and installs event filter watching for close event. Alternativelly, you could make a helper class to load children from the ui file. The first method is the most straightforward, I've included the other two for completeness sake (it would work if you weren't in control of the ui file, for example).
Message 7 of 13
Ok thanks, I'll try to work on this.
Didn't expect  to be so complicated for such a simple thing 😅
Message 8 of 13
denisT.MaxDoctor
Just noticed now. This is a great find! 😎👍
Message 9 of 13
Swordslayer
There's also a cleaner way without introducing extra variable:
testDialog.closeEvent = fn customCloseEvent evnt = (py.print "custom code"; QtWidgets.QDialog.closeEvent testDialog evnt)
Message 10 of 13
denisT.MaxDoctor
Do you know how to get the sender of an event? I hope there is some hidden trick that I don't know 😉
Message 11 of 13
denisT.MaxDoctor
the most interesting thing here is how easily you can create a new QObject property
Message 12 of 13
Swordslayer
Usually, I don't connect multiple signals to a single event handler but if I had to do that, I'd make the event handler receive extra sender argument and when connecting it, I'd connect it to a curried function (via functools.partial) that would carry the sender with it.
Message 13 of 13
denisT.MaxDoctor
this is what I usually do but still looking for a better solution:
fn onEvent event sender: =
	<py>.print "... " event sender
	qt_bt = <qt>.QPushButton()
	qt_bt.<event> = (fn __ event = onEvent event sender:qt_bt)
PS. oops... the idea seems to be correct, but there is a problem with local scope (or garbage collection(?)). As soon as I find a solution, I'll post the update.
