Maxscript ProBoolean problem with the “AddMethod”
p.hubertQSU4H
p.hubertQSU4H
Hello everybody;
I am currently developing a script where I need the Proboolean. But I can’t get it to change the adding method. I have no problem adding my boolean and changing operation but changing the add method to “reference” (and the materials method) doesn’t work. It still keeps the default method which is “move”.
b = box pos:[ 10,10,10] isSelected:on
c = box();
ProBoolean.setoperandA b
ProBoolean.SetBoolOp b 3
ProBoolean.setoperandB b c 0 1
when I refer to the documentation the 0 is supposed to pass me the method in reference.
Anyone have a solution ?
Pierre
denisT.MaxDoctor
c = box();
I remember the problem. First, try to use Boolean2 instead:
	delete objects
	a = box width:20 length:20 height:20 wirecolor:green isselected:on
	b = geosphere radius:8 pos:[-10,0,0] wirecolor:orange
	max create mode
	boolObj.createBooleanObject a b 2 2
... or Boolean3:
	delete objects
	max create mode
	startobjectcreation boolean3
	bool = selection[1]
	bool.AppendOperand bool b false
	bool.SetOperationType 2 #subtraction
boolean2 has some advantages over boolean3, but boolean3 is faster for some topologies...
If you need ProBoolean no matter why... I can show you how next time. But I don't recommend using ProBoolean for simple mesh geometry.
p.hubertQSU4H
Hi Denis, thanks for your reply.
I've spent a lot of time on forums and your reputation precedes you.
I started using Boolean3, but the problem is that it piles up IDs when I merge my meshes. I end up with the right shaders on the right faces but with a multi sub of 400 shaders. That's why I turned to Proboolean, which will keep my multi sub clean after the operations.
I'm on a non-destructive workflow, with splines as references. And I have to apply my Boolean operations as references while keeping the ability to change my IDs at any time (at the lower level)."
I may have missed something with Boolean3 for the IDs. But if you have a solution to make Proboolean work as a reference, I'm interested.
denisT.MaxDoctor
did you try both material options?
.materialOption: integer
The Material setting for the Boolean:
0 - Apply Operand Material
1 - Retain Original Material
denisT.MaxDoctor
fn setAddMethodByHWND method =
	hwnd = windows.getchildhwnd #max "Start Picking"
	hwnd = hwnd[1]
	for k = 0 to method do hwnd = uiaccessor.getnextwindow hwnd
	uiaccessor.pressbutton hwnd
	delete objects
	max modify mode
	proboolean.createBooleanObject a undefined 2 0 0
	select a
	add_method = 0 -- reference
	setAddMethodByHWND add_method
	proboolean.SetOperandB a b add_method 0
	modpanel.setcurrentobject a
