C++ TreeView
C++ TreeView
orion201324
C++ TreeView
orion201324
Hi everyone,
I'm using C++ to build a tool which should make use of a Tree View, and that allow users to drag and drop nodes into it. However, I only see examples in the documents of tools using MAXScript to create a Tree.
Currently, I can add a TreeView into the resource file using:
CONTROL "", IDC_MY_TREE "SysTreeView32", WS_BORDER | WS_HSCROLL | WS_TABSTOP, 50, 110, 60, 50
Which will make it appear in the UI. Unfortunately I don't know what parameter types to use to register this in a Parameter Block, or enable drag-and-drop.
Is this method possible? Or is there a better alternative for including hierarchical lists in the dialog.
klvnk
think you're out of luck, there's no parameter ui type to tie listview to parameterblock
Parameter UI Control Types
you'll have to write your own code to link it with/sync it with a TYPE_INODE_TAB
orion201324
@klvnk that's a pity! Thanks for the help.
klvnk
also I think you'll have difficulty dragging Nodes off the viewport or the scene explorer without max changing selection, not saying it's not possible but I don't think it's trivial/easy.... stuff like this is usual handle with a
PickModeCallback, PickNodeCallback  combo and or an HitByNameDlgCallback
istan
There's also dotNet but... well.. actually this was the point, where I switched to C++ and QT..
