maxscript morpher channel name
please i want to write maxscript code to set morpher value by using channel name not by channel_index
WM3_MC_SetValue $.Morpher 1 20.0
WM3_MC_SetValue $.Morpher $Teapot002 20.0
or
$.morpher[1].value = 50
$.morpher[Teapot002].value = 50
davidlanier
I am not sure this is feasible directly though you could do :
--this is pseudo code, I haven't tested it :
function GetIndexFromName name =
 index = -1 --Not found yet
 numchannels = WM3_NumberOfChannels ($.morpher)
 for iChannel = 1 to numchannels do(
    string_nodename = WM3_MC_GetName ($.morpher) iChannel
    -- could also use <node>WM3_MC_GetTarget to get the node directly
   if (nodename == name)do (
       index = iChannel
       break
index --This returns the index value
idx = GetIndexFromName "Teapot002"
if( idx != -1) do(
  WM3_MC_SetValue $.morpher idx 20
David Lanier
Principal Software Engineer
3ds Max Rendering Team
thank you for your response
the code not working
i searched about this function in past time and find a function not documented in maxscript help do this but i can not remember the code now
it was one line or tow lines only
please try to find it to me
and try to tell developers in Autodesk 3ds max to add this function to morpher class beacuse it very useful
thanyou
like this
WM3_MC_SetValuebyname $.morpher Teapot002 100
