Announcements
MaxScript Methodology: Loops...
blakestone
blakestone
Good morning, this post is more about the understanding of how to approach MaxScript when it is being continuously executed which I assume will be using some form of Loop to keep the script active, or maybe there is a mode which you can put the script into?
An example of this would be say using the "PainterInterface" you would first execute the Painter script and then execute a Loop to keep the script active and obtain the user input data etc. However I am finding that running a Loop in instances like this I have troubles exiting the Loop or the Loop interferes with whats being executed (mostly performance wise).
Would there be a particular mode that you can put the script into rather than a Loop which you can say Enable/Disable via a GUI Button. Such as a button like ... ... etc.
Again this is not specific to Painting it can be for anything which requires continuous updating until the user decides to stop executing.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Steve_Curley
I don't believe you need a loop - at least not in the sense of looping until the painting (or whatever) is finished.
Have a look at the "How To..." section of the Maxscript Help - several of them require multiple clicks, one of them is actually about painting on a bitmap. They may be of some use.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
