MaxScript Methodology: Loops...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning, this post is more about the understanding of how to approach MaxScript when it is being continuously executed which I assume will be using some form of Loop to keep the script active, or maybe there is a mode which you can put the script into?
An example of this would be say using the "PainterInterface" you would first execute the Painter script and then execute a Loop to keep the script active and obtain the user input data etc. However I am finding that running a Loop in instances like this I have troubles exiting the Loop or the Loop interferes with whats being executed (mostly performance wise).
Would there be a particular mode that you can put the script into rather than a Loop which you can say Enable/Disable via a GUI Button. Such as a button like ... ... etc.
Again this is not specific to Painting it can be for anything which requires continuous updating until the user decides to stop executing.
