MaxScript - Major Double GAMMA issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all
I'm busy with a script, to RESET all gamma values to default. However, I'm have major intermittant issues and struggling to get to the bottom of it. Sometimes it works and simetimes it doesn't. Then suddenly, after running it a couple of times, modifying and essentially going back to the beginning, code that didn't work 5 minutes ago, suddenly works.
I'm getting double GAMMA issues, sometimes in the viewport AND in the material editor for bitmaps. Other times JUST the viewport. Then suddenly for no reason it starts to work. I tried with various different versions of Max at different offices (2014-2016), with the same results in each.
FreeSceneBitmaps() gc light:true IDisplayGamma.gamma = 2.2 IDisplayGamma.affectColorPickers = true IDisplayGamma.affectMEdit = true fileingamma = 2.2 IDisplayGamma.colorCorrectionPrefMode = #gamma IDisplayGamma.colorCorrectionMode = #gamma fileoutgamma = 2.2
I also tried using ONLY IDisplayGamma.colorCorrectionPrefMode = #gamma or only IDisplayGamma.colorCorrectionMode = #gamma
I also tried freeing bitmpas between each command.
I also tried using code and setting all gamma to 1 and then this code. Same result
I tried on a simple scene with a box and 2 bitmaps applied to different faces.
I also tried switching between realistic and shaded viewports, same story
What am I missing here?
