Maximum Nested Error Dialog Depth Reached
eesnsk
eesnsk
Hello, everyone.
 I have a problem and can't find the solution in other forums... When I choose an object and try to convert to editable poly then appear the windows with error and other stuff. Also this winsows appear when I start 3ds Max.
 I've just started to learn 3ds Max, so please try to explain what happens here without difficult terms
P.S.I`ve already download the update of 3ds Max 2017, but it hasn`t helped.
Swordslayer
eesnsk
Here it is:
-- Error occurred in anonymous codeblock; filename: F:\Autocad\3ds Max 2017\stdplugs\stdscripts\filterfunctions.ms; position: 3267; line: 92
-- MAXScript Auto-load Script Error - F:\Autocad\3ds Max 2017\stdplugs\stdscripts\filterfunctions.ms Exception:
-- Syntax error: at ?, expected member name or local function:
-- In line: ? (
Swordslayer
There you go, there's something wrong with that file, F:\Autocad\3ds Max 2017\stdplugs\stdscripts\filterfunctions.ms
Uninstalling and reinstalling would help in this case as it purges the max root folder, but it might even help removing the question mark on that line (seems like edited just by mistake).
eesnsk
Thank you so much! reinstalling has helped!
