mapbutton - how to use in a material
DEDE1709_2
DEDE1709_2
I´m trying to make a "mapbutton" work like a normal map button in a standard material.
What I mean is a map button / slot where I can select a map from the map list when the
button is empty and go one level deeper to the map when a map is inside the button and
it´s clicked.
The current maxscript mapbutton can open the new maps selection dialog, but when a map
is assigned it´s not automatically acting like the usual map buttons in standard materials.
I´ve not been able to successfully use this button in a way that users are used to it. The only
thing that I found out was that assigning a variable to the button itself will help.
But there is still a problem with this method, as I cannot assign a specific map from a material
to the button, it´s always the same diffuse map that is connected to the button.
example:
parameters main rollout:mapbuttontest
source_map_name type:#string ui:source_map
rollout mapbuttontest "map button test"
mapbutton source_map "< Source Map >" tooltip:"Select Source Map" width:300 height:20 align:#center offset:
Does anyone know how this could be solved ?
Best,
Martin
Swordslayer
A few things to note. First, the parameter definition type should definitely be type:#texturemap, not string. Second, is this a scripted material or a scripted texture map or just CA? In the first case it should do exactly what you want (and a bigger chunk of code showing the problem would be handy to find out why it doesn't), if it's just CA.. well, you could always have another button that would send the linked texturemap to the active slot of material editor, for example, but that's about it.
DEDE1709_2
Thanks. This could be the problem. I will give it a try and let you know if it´s solved.
DEDE1709_2
Ok, I´ve tried several methods, but I can´t manage to make it work. What I´m trying to achieve is a simple map button that triggers an event when a map is selected. Here is the simple script:
plugin material mapbuttontest
classID:#(0x4399744a, 0x3330f8d2)
extends:Standardmaterial replaceUI:false
parameters source rollout:source_picker
source_map_shader type:#texturemap ui:source_map
rollout source_picker "Pick Source Map"
on source_map_shader changed map do
print "I´ve picked a source map!"
on source_map picked texmap do
print "I´ve picked a source map"
While the mapbutton will act as expected, I cannot find a way to let it trigger an event. In this example, non of the two on events work and no print function will be executed. I´ve also tried on .... pressed and on .... selected but both don´t work.
I´m lost and I think that there is something pretty obvious that I´m missing.
Any help is really appreciated!
Swordslayer
It is, it goes back to the CA vs scripted material/map differences. In the former case event handlers work as expected, in the latter you have to use the set event of the parameter itself. The relevant piece of code for you would be:
on source_map_shader set val do
By the way, the code tag keeps indentation, classic quotes and other nice things, be sure to use it when including code next time 🙂
DEDE1709_2
Thank you sooo much!!! This is exactly what I needed and it works perfectly. Really appreciated!
Here is my code:
plugin material mapbuttontest name:"mapbutton test"
delegate.maps = val
delegate.maps = val
delegate.maps = val
BTW: If you are interested in any of my products at http://www.vizpark.com, drop me a personal message.
