Loops optimization
Loops optimization
antoine_allazHXWTY
Message 1 of 15
Loops optimization
antoine_allazHXWTY
I'm looking for a process to automate loops... I'm sure there is a logical way to do it, but I can't find.
I want to have the list of all nodes and groups in my selection, sort hierarchically (you can see the result after). So I create some loops to analyze the parent/children structure. It's works, but I need to write all loops manually. Is there a simple way to do it?
for i = 1 to sel.count do (
	if (sel[i].parent == undefined) or ((findItem sel sel[i].parent) == 0) then (
		print (" "+sel[i].name)as string
		for j = 1 to sel.count where sel[j].parent == sel[i] do (
			print (" ├ "+sel[j].name) as string
			for k = 1 to sel.count where sel[k].parent == sel[j] do (
				print ("  ├ "+sel[k].name) as string
				for l = 1 to sel.count where sel[l].parent == sel[k] do (
					print ("   ├ "+sel[l].name) as string
					for m = 1 to sel.count where sel[m].parent == sel[l] do (
						print ("    ├ "+sel[m].name) as string
						for n = 1 to sel.count where sel[n].parent == sel[m] do (
							print ("     ├ "+sel[n].name) as string
							for o = 1 to sel.count where sel[o].parent == sel[n] do (
								print ("     ├ "+sel[o].name) as string
my result :
"level0_Box001"
"level0_Group001"
"├ level1_Box001"
"├ level1_Group002"
" ├ level2_Group002_Box003"
" ├ level2_Group002_Box004"
" ├ level2_Group002_Box002"
"├ level1_Group003"
" ├ level2_Group005"
"  ├ level3_Group005_Box009"
"  ├ level3_Group005_Box010"
"  ├ level3_Group005_Box011"
"  ├ level3_Group005_Box012"
"  ├ level3_Group005_Box013"
"  ├ level3_Group005_Box014"
" ├ level2_Group004"
"  ├ level3_Group004_Box005"
"  ├ level3_Group004_Box008"
"  ├ Level3_Group006"
"   ├ level4_Group006_Box006"
"   ├ level4_Group006_Box007"
"level0_Group007"
"├ level1_Group007_Box007"
"├ level1_Group007_Box006"
"├ level1_Group007_Box005"
Thanks for your help,
Best Regards,
Antoine
Accepted solutions (3)
Replies (14)
Message 2 of 15
denisT.MaxDoctor
What do you know about the recursing function? Google it... there are examples of how to use it in MaxScript Help.
If you have any questions, I'm available to answer them.
Message 3 of 15
denisT.MaxDoctor
fn expand_node node tab:"" =
	print (tab + node.name)
	for child in node.children do expand_node child tab:(tab + "\t")
delete objects
bip = biped.createnew 170 0 [0,0,170*0.96]
expand_node bip
Message 4 of 15
istan
have you heard about recursive calling a function?
e.g.
fn disp sel pre:"" = (
  for s in sel do (
    format ( (if pre!="" then (pre + "|+ ") else "") + s.name + "\n")
    if s.children.count then (
      disp s.children pre:(pre+"  ")
disp sel
Message 5 of 15
antoine_allazHXWTY
Thank you very much for your answers ! No, I never heard about recursive function. So I'll investigate.
Message 6 of 15
antoine_allazHXWTY
So it's done, thank you !
sel = #()
sel = getCurrentSelection()
gr_parent = #()
gr_list = #()
for i in sel do (
	if (i.parent == undefined) or ((findItem sel i.parent) == 0) then (
		append gr_parent i
for i in gr_parent do (
	expand_node i
	append gr_list ("\n")
print gr_list
Message 7 of 15
klvnk
nothing to do with the question per se but I did discover the calling c++ mxs functions  with optional arguments (being used) considerably slower
Message 8 of 15
denisT.MaxDoctor
is it specifically for recursive calls?
it depends on how the C++ function parses optional arguments... yes it's slower, but not dramatically I hope.
Message 9 of 15
klvnk
there's a set of standard macros/functions for this eg BOOL use_edges = bool_key_arg(use_edges, temp, TRUE);
here's the example when I found it, it was testing various get all element routines as I'd added it  to adjedge and wanted to see how it compared...
	count = 1000;
	n = $;
	t = timeStamp()
	for i = 1 to count do meshop.getElements n;
	format "meshop.getElements = % \n" (timeStamp() - t)
	t = timeStamp()
	for i = 1 to count do meshop.getAllElements n;
	format "meshop.getAllElements = % \n" (timeStamp() - t)
	t = timeStamp()
	ae = adjedge.buildEdges n;
	for i = 1 to count do adjedge.getAllElements n ae;
	format "adjedge.getAllElements unsupplied = % \n" (timeStamp() - t)
	t = timeStamp()
	for i = 1 to count do adjedge.getAllElements n ae use_edges:false;
	format "adjedge.getAllElements optional = % \n" (timeStamp() - t)
adjedge is a object type I added using my own edge list code the other functions aren't really relevent the results
were
meshop.getElements = 276
meshop.getAllElements = 295
adjedge.getAllElements unsupplied = 58
adjedge.getAllElements optional = 534
when I originally ran it with the optional arg I was wtf why is the adjedge version so  much slowler when it should be miles ahead ! then I added the unsupplied. It's such a hit I won't be using optionals from now on.
edit: seems to be an issue when the arg == default  🤔
Message 10 of 15
denisT.MaxDoctor
It is quite clear that there are no miracles. A function with optional arguments must go through the whole list of arguments and find the ones that must be processed... If the function will not handle them, it makes no difference whether they are basic or optional.
you can set a mandatory order of keys and their data type, take the key in order, check for its presence, and do not check the data type... then everything will be fast. 😁
Message 11 of 15
denisT.MaxDoctor
So for functions that require a lot of different parameters, I usually pass one on the "structure" type... and then do all the "parsing" at the c++ type level.
Message 12 of 15
denisT.MaxDoctor
Actually, the biggest issue with MXS loops is memory leakage. Everything else is manageable. 😁
fn measure_heapfree count:1000 =
	t0 = timestamp()
	h0 = heapfree
	n = count
	while n > 1 do
		k = n - 1
		while k > 0 do
			k -= 1
		n -= 1
	#(count, n, k, timestamp() - t0, h0 - heapfree)
measure_heapfree()
Message 13 of 15
A012255
Not in general, as there is not much code for parsing an optional argument. But of course it depends how often you call it in a loop 😉
But usually this will be the point, where I move the whole loop to C++.
However parsing "Name literals" like #foo1, #foo2 takes longer as string compares will be needed. But even then, there is not much difference if integers are used instead.
There might be a difference between release and debug version?
Message 14 of 15
denisT.MaxDoctor
Exactly the opposite... Comparing names is much faster than comparing strings. Key search (name comparison) does nothing with strings.
Message 15 of 15
denisT.MaxDoctor
Of course, it doesn't make sense to make a c++ function to extend MXS like:
deletePolyVertex <node> [index:<int>]
we need to convert the node to a reference,  check the class, get MNMesh, find the key, get the vert index... And we must understand that the system in general has to evaluate the values (arguments) that are passed to c++. But it makes sense if we pass one or multiple vertices where <index key> is optional and can be an integer (float, double, int64, any number), or as well #selection. #all, bits, array. etc...
