loop issues with object class
Hey, I try to do this little script to delete every lights and cameras depending of the choice of the user :
rollout test "B71 Creative"
checkbox del_lit "Lights"
checkbox del_cam "Cameras"
button export_obj "delete"
on export_obj pressed do
if del_lit.state == true do
for obj in lights do
delete obj
if del_cam.state == true do
for obj in cameras do
delete obj
createDialog test 100 70
But the probleme is when a I check one of the checkbox I receive this error :
-- Error occurred in export_obj.pressed(); filename: D:\script\; position: 259; line: 14
-- Frame:
>> MAXScript Rollout Handler Exception:
-- Unknown system exception <<
I can't find where the problem come from.
And the weird thing when I execute directly this line it's works :
delete obj
delete obj
stigatle
creat a array to hold the objects, then delete the objects in the array helps.
tempArray = #()
append tempArray obj
delete tempArray
Thanks very much It's work now
Steve_Curley
Yes, but as both Lights and Cameras are built-in collections,
if del_lit.checked then
delete lights
if del_cam.checked then
delete lights
The point is, though, well made - collections are a kind of array, but they're likely to get modified in the background, so you're hitting an "empty" array location. All to do with the initial state of the array at the start of the looping procedure and it being changed in each iteration of the loop.
Another way to do this is to treat the collection as an array and work DOWN it, not UP.
for o = lights.count to 1 by -1 do
delete lights
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
