Looking to create a script that would play an audio file on starting rendering.
Matthew_Polewiak
Message 1 of 8
Matthew_Polewiak
I would like to create a script that plays an audo file (mp3 format though I can convert it if needed) whenever I start the rendering process (I usually start it with the shift +Q/Render production option).
I tried creating the script through chat gpt but it seems the script that I was given (written below) doesn't work in 2024 version of 3ds max.
global renderEvents = undefined
fn playSoundOnRenderStart =
local soundPath = @"C:\Path\to\your\sound\clip.mp3" -- Replace with the actual path to your sound clip
playSound soundPath
fn onRenderStart evs =
if evs.startRendering do
playSoundOnRenderStart()
fn setupRenderEvents =
if renderEvents == undefined do
renderEvents = dotNetObject "Autodesk.Max.RenderEvents"
dotNet.addEventHandler renderEvents "RenderStart" onRenderStart
setupRenderEvents()
Replies (7)
Message 2 of 8
dmitriy.shpilevoy
Try this
player = dotnetobject "System.Media.SoundPlayer"
path = @"c:\Windows\Media\chimes.wav"
player.SoundLocation = path
player.Load()
function renderPlay = (
	format "playing\n"
	player.Play()
rollout r_play "play" (
	button bt_play "play" width:120 --align:#left
 	on r_play open do (
 		callbacks.removescripts id:#rplaycb
 		callbacks.addscript #preRender renderPlay id:#rplaycb
	on r_play close do (
	on bt_play pressed  do (
		renderPlay()
createDialog r_play 200 60
Message 3 of 8
Matthew_Polewiak
It works thanks a lot,
Do you know how can I make 3Ds Max run the script automatically on launch?
Message 4 of 8
dmitriy.shpilevoy
Run
GetDir #startupScripts
in listener and put script there. Note that as it is script will open rollout each time and stop working if you close it.
You can leave the sound stuff and remove rollout from it, but then it will keep callbacks registered.
Message 5 of 8
Serejah
this kind of script deserves its own macro button to toggle on/off state
Message 6 of 8
denisT.MaxDoctor
Is there some special point to this, or is it just to make the process less boring?
Message 7 of 8
Matthew_Polewiak
The latter option i suppose, it's kind of an inside joke between me and my brother.
Message 8 of 8
denisT.MaxDoctor
then you better go to Reddit
