Limit the time one step in a loop can take
roger.olofsson
roger.olofsson
I have a script that I use for batch importing geometry. Sometimes there are "faulty" geometry in the imported file and the loop gets stuck which means that the process isn't done in the morning which casuses problems.
Is thera a way to limit the time that a step in a loop is allowed to process? If the import isn't finished in 1 hour continue to the next file in the loop.
Roger
blakestone
You could use "TimeStamp" example :
	local time_start = timeStamp()
	while (true) do (
		-- import script
		local time_current = timeStamp()
		local time_difference = (time_current - time_start) / 1000		-- seconds
		if (time_difference >= 10) then (
			exit
	print(time_difference)
The above script will exit the loop after 10 seconds... you could do 3600 for 1 hour
if (time_difference >= 3600) then...
roger.olofsson
Thanks, I will give that a try.
Roger
