Import normalmaps in slate material editor bases on bitmap file location
peterv42
Message 1 of 9
peterv42
This is the last step in automating a workflow i use the confert FBX to a 3th party format.
In this stage I am in the slate material editor and I have materials with a linked diffuse bitmap.
I want to inport a normal/bump map on al materials based on the folder of the diffuse map.
for the right filename of the normal map i have this:
NormalMapName = (getFilenamePath file + getFilenameFile file + "_n" + getFilenameType file)
sceneMaterials["naam_opaque"].bumpMap = Bitmaptexture fileName:NormalMapName
I found how i can read the Bitmaptexture name
bMaps = getClassInstances Bitmaptexture
but i need the bitmap folderlocation.
I hope that sameone can help me with this.
Greeting Peter
Replies (8)
Message 2 of 9
peterv42
I now have this:
mMaps = getClassInstances bitmaptexture
--itterate all bitmaps
for m in mMaps do
	print(m)
	pName = getFilenamePath m.filename
	fName = getFileNameFile m.filename
	fExt = getFileNameType m.filename
	NormalMapName = (pName + fName + "_n" + fExt)
	--rename bitmapName
	m.Name = newPath+fName+fExt
	--rename/set location
	m.filename = newPath+fName+fExt
	sceneMaterials["naam_keyed_test"].bumpMap = Bitmaptexture fileName:(NormalMapName)
This script places a bitmap with the correct filename and connects it to the bumpmap but of cource only on the "naam_keyd_test" material.
how do i make it that it will put it on all materials?
This did not do the trick:
sceneMaterials[m].bumpMap = Bitmaptexture fileName:(NormalMapName)
Greetings Peter
Message 3 of 9
denisT.MaxDoctor
It seems to me that you are not quite accurate in formulating the problem ... judging by the code I see above:
Do you want to set the material's Normal bitmap using the same material's Diffuse bitmap information (filename)?
Message 4 of 9
peterv42
Sorry for not explaining it correctly.
Yes this is what i am trying. I found how to itterate over the materials
--itterate all materials
for mat in scenematerials do
   print(mat)
	for m in mMaps do
			sceneMaterials[mat].bumpMap = Bitmaptexture fileName:NormalMapName
now i think i need to first itterate the material and then the textures. i tried same variation but got errors as a result.
hope you can help with the last stap.
Greetings Peter
Message 5 of 9
denisT.MaxDoctor
how to collect materials you already know...
here is how to replace Bump Map bitmaptexture based on Diffuse Map texture filename:
fn makeSpecialName filename postfix:"" tag: =
	path = getfilenamepath filename
	file = getfilenamefile filename
	type = getfilenametype filename
	if iskindof tag String then
		if matchpattern file pattern:("*" + tag) do
			file = replace file (file.count - tag.count + 1) tag.count postfix
	else file += postfix
	path + file + type
fn xchangeBumpTextures mats: =
	for mat in mats where isproperty mat #diffuseMap and isproperty mat #bumpMap do
		dtex = getproperty mat #diffuseMap
		if iskindof dtex Bitmaptexture and iskindof dtex.filename String do
			file = makeSpecialName dtex.filename postfix:"_n"
			btex = Bitmaptexture filename:file
			setproperty mat #bumpMap btex
/* using:  for example for all medit materials >>
xchangeBumpTextures mats:meditmaterials
when you make the new filename you have two options:
1. replace old tag (for example, filename: small_table_c.jpg and where tag is "_c") with new postfix
2. just add a new postix to filename
Message 6 of 9
peterv42
Again thank you for your time. It could by i do not understand your script or I explained my goal not good enough.
I do not want to replace myBump map. I only have meterials (more then 1) and on all of them I only have a Diffuse color texture (see screenshot 1)
In my sceneassets/images folder I have the diffuse texture "ker_pichlavej_3_ca.tga" and the BumpMap texture "ker_pichlavej_3_ca_n.tga" for all my scenes and there materials.
the result must be as in screenshot 2
Greetings Peter
Message 7 of 9
denisT.MaxDoctor
it's exactly what my last code does do...
xchangeBumpTextures mats:(sme_getSelectedMaterials())
Message 8 of 9
peterv42
Hello dennisT,
Your last hint did the trick. I was trying to get it to work on the code below becouse I wrote about it in the beginning of the mail.
   print(mat)
But you were pointing to a other mail correspondens we we had about naming material with script.
So for who did not see that other mail or like me who do not get the hint the below total script.
With this script you need to select your material in the 'slate material editor' and it will place a Bumpmap bases on the name of your Diffusemap.
	path + file + type
fn sme_getSelectedMaterials view: =
	if view == unsupplied do view = sme.getview sme.activeview
	tv = trackviewnodes[#sme]
	vsub = tv[view.name]
	for k=1 to vsub.numsubs collect
		sub = vsub[k]
		ref = sub.reference
		node = view.getnodebyref ref
		if node.selected and iskindof ref Material then ref else dontcollect
@denisT.MaxDoctor thank you for your help hints and patience
Message 9 of 9
peterv42
It has been some time since I last used this script but It looks like this script is not working anymore in 3dsMax version 2020. Does anyone know if the Max version could be the problem?
Greetings,
Peter
