How to write this in c#?
maxyweb
maxyweb
I figured out how to work with objects a little, but I couldn't find how to work with materials. And in general, does anyone know where to find detailed documentation?
if obj.material.base_color_map != undefined then
		local bmt = Bitmaptexture();
		local bmt_file = texpathD
		local bmp = openBitmap bmt_file gamma:2.2;
		bmt.bitmap = bmp;
		obj.material.base_color_map = bmt;
		obj.material.base_color_map.Reload();
		obj.material.base_color_map.name = "D";
		showTextureMap obj.material obj.material.base_color_map on
istan
When MXS is so simple for you, why don't you simply execute your MXS code via C#?
There should exist a C# function for calling it. Sry, I know it only for C++.
