Announcements
accessing .vrscene exporter window from script?
inquestudios
inquestudios
I need to open Vray .vrscene exporter and control its UI from my script.
The problem is when I run vraySceneExport() window shows up, but does not draws its interface until script is finished.
Is there any way to open this window async from main script?
denisT.MaxDoctor
finish the script, let the VRay dialog open, and use DialogMonotorOPS to initiate a new script run for custom settings
inquestudios
Maybe there's another way to bring that window bypassing MAXscript?
Some ctypes mumbo-jumbo, maybe? 😄
denisT.MaxDoctor
did you try vrayExportVRScene?
inquestudios
vrayExportVRScene actually exports the .vrscene, while I need to use "Analyze" routine from dialog window,
and scrape results from log window.
