How to use a global struct in mcr script?
h.schoenberger
h.schoenberger
Hi
I have written some functions to be executed from the 3dsmax menu.
Therefore I created a file 3dsmax/Macroscripts/myScript.mcr.
As I want to re-use functions for multiple commands, I created a struct for it.
If I place a new struct inside the macroscript function, then I can use that struct.
But I need to use that struct in multiple different commands.
But if I try to define the struct outside the Macroscript function, it is not found.
Anything I am missing?
Some example:
struct modSceneScripts_global
,fn splitFileName &file &ext =
        for c = file.count to 1 by -1 do
            if (file[c]==".") then (
                ext= substring file c (file.count - c+1)
                file= substring file 1 (c-1)
                return OK
macroScript Mod_new
category:"Inhouse"
buttontext:"Modify Scene"
tooltip:"Modify Scene"
struct modSceneScripts_local
                return OK
    localClass= modSceneScripts_local()
    globalClass= modSceneScripts_global()
blakestone
To my understanding every struct/function which is called, that is not within (), is stored globally. Because of this you can call all your structs/functions when starting 3dsMax using fileIn and they should all be accessible from other scripts. This is how I have successfully done this.
1. Save all your structs/functions to their own individual files (this makes it easier to manage) and store them in a folder somewhere eg.
  • c:\maxscripts\script_001.ms
  • c:\maxscripts\script_002.ms
  • c:\maxscripts\script_003.ms etc.
2. Create a maxscript eg. "my_structs.ms" like the following this and place it within your 3dsMax startup folder:
c:\program files\autodesk\<version>\scripts\startup
	local files = getFiles "c:\maxscripts\*.ms"
	for i in files do fileIn i
Now when you launch 3dsMax it will run the "my_structs.ms" and load all your structs/functions globally and will be accessible to all your other scripts.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
How can I do this for Python scripts and functions?
blakestone
Are you wanting to know how to make a range of Python functions global or how to access global functions in Python?
I have scripted a little with Python but not in 3dsMax so unsure what you can and can't do with it.
