How to retrieve the axis order of an euler controller (EULER_CONTROL_CLASSID)
I am attempting to retrieve the "ordering" information from a Euler controller (EULER_CONTROL_CLASS_ID).
I read in several places that I should use the Control::GetLocalTMComponents() but I tried calling the method on the controller and on its parent (the PRS controller). In both cases the rotRep component of the TMComponentsArg struct was kUnknown.
Thanks in advance!
I discovered that I can do
IEulerControl* pEulerControl = reinterpret_cast<IEulerControl*>( pRotationController->GetInterface(I_EULERCTRL) );
IEulerControl has the method GetOrder() and returns the order of the xyz eulers as defined in euler.h
But I always get zero no mater what!
Any Idea? 🙂
Well, GetOrder() seems to work! :).
The problem was my first tests were with static objects without keys in the rotation controller.
Thanks!
