How to remove unused map verts?
dmitriy.shpilevoy
dmitriy.shpilevoy
Hello, folks.
Editable Poly has a button for it, but can't find a way to call it from script.
Can probably find them by going through geo verts, collecting corresponding UV verts and then substracting it from all map verts, but I still don't know how to remove those UV vertices.
My backup plan is to add Edit_Poly and use its #RemoveIsoMapVerts. Feels nasty though.
MartinBeh
This documentation  (search for "RemoveIsoMapVerts") seems to suggest you can use
EditablePoly>.buttonOp #RemoveIsoMapVerts
You might have to be in the right sub-object mode before you run this, e.g.
max modify mode
subobjectlevel = 1
(not sure you need subojectlevel = 1  (= vertex) SO mode or something else)
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
dmitriy.shpilevoy
Thank you. In this case it does the trick.
Still don't understand why this functionality is not exposed normally to maxscript 8(
