How to read ribbon checkbox value with maxscript or dotnet for my custom ribbon UI.
sharfy
Message 1 of 8
sharfy
How to read ribbon checkbox value with maxscript or dotnet for my custom ribbon UI. There are some functions like OBJPaintGetSetting and VCGetSetting to read Object Paint Tab, but is no source code available for them
Replies (7)
Message 2 of 8
denisT.MaxDoctor
If you have created a custom ribbon UI, you probably have a better understanding of how to get the values. 😁
Message 3 of 8
sharfy
I just want to use MaxRibbon for my ui. not able to access spinner value or ischecked state from maxRibbon.
like object paint tools on ribbon
OBJPaintGetSetting 13
returns follow Stroke value state
Message 4 of 8
denisT.MaxDoctor
How do you add your stuff to the ribbon? (show the code or an example)
Who can know how to read the data if we don't know how it was added?
I get the feeling that you are doing some hacker manipulation without understanding what or why... Your question just doesn't make sense from the point of view of how Ribbon works.
Message 5 of 8
trykle
ComponentManager = dotnetclass "Autodesk.Windows.ComponentManager"
tabs = ComponentManager.Ribbon.Tabs
tabs.Count
tab5 = tabs.Item[4]
tab5.name
MY_CKB_1 = tab5.FindItem "MY_CKB_1"
MY_CKB_1.IsChecked
Some keywords come from Cgsociety (although it has been closed).
Message 6 of 8
sharfy
Thanks its working
Message 7 of 8
sharfy
I am adding stuff in ribbon by adding xml file in
C:\Program Files\Autodesk\3ds Max 2023\en-US\UI\Ribbon\Extensions
file
<wpf:ResourceDictionary
xmlns="clr-namespace:WPFCustomControls;assembly=WPFCustomControls"
  xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:sys="clr-namespace:System;assembly=mscorlib"
xmlns:ads="clr-namespace:Autodesk.Windows;assembly=AdWindows"
xmlns:wpf="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:wpfcust="clr-namespace:WPFCustomControls;assembly=WPFCustomControls">
<MaxRibbonTab x:Key="Select" Title="Select" Name="Select">
<MaxModelingRibbonPanel IsAnonymous="False" IsVisible="True" ResizeStyle="NeverHideText, NeverCollapsePanel">
<MaxRibbonPanelSource Title="Select Tools">
<ads:RibbonRowPanel AllowInToolBar="false" MinWidth="100" ShowText="false" >
<ads:RibbonButton Text="Select All" ShowText="True" CommandHandler="{wpfcust:ActionItem MacroName=selectObjects, MacroCategory=test}"/>
</ads:RibbonRowPanel>
<ads:RibbonSeparator AllowInToolBar="false" MinWidth="0" ShowText="false" />
<wpfcust:MaxRibbonCheckBox IsCheckable="true" ShowText="True" Text="shapes" Id="shp_ckb"/>
<ads:RibbonRowBreak AllowInToolBar="false" MinWidth="100" ShowText="false" />
<wpfcust:MaxRibbonCheckBox IsCheckable="true" ShowText="True" Text="geometry" Id="geo_ckb" />
</MaxRibbonPanelSource>
</MaxModelingRibbonPanel>
</MaxRibbonTab>
</wpf:ResourceDictionary>
macroScript selectObjects category:"test" tooltip:"testSel"
on execute do (
selTab = undefined
for i = 0 to tabs.count-1 do (
if tabs.Item[i].Title == "Select" then selTab = tabs.Item[i]
shapeCkb = selTab.FindItem "shp_ckb"
geoCkb = selTab.FindItem "geo_ckb"
if (shapeCkb.IsChecked and geoCkb.IsChecked) then (select objects)
else if shapeCkb.IsChecked then (select shapes)
else if geoCkb.IsChecked then (select geometry)
Message 8 of 8
denisT.MaxDoctor
file
</MaxRibbonTab>
I assumed something like that... That's not the right way to design and develop tools. It should be done through .NET methods, not by manually editing an XAML file.
