How to make the dialog stay only on top of the 3ds max window
Ken_GordonQRB22
Ken_GordonQRB22
I made a QT dialog, tried several methods, I use dialog->show() so that the dialog does not block the 3dsmax window, but I can’t get the dialog to be on top of only the 3dsmax window, the window either hides when the window is activated 3dsmax or hangs on top of all the windows. Tell me which way to dig?
denisT.MaxDoctor
Are we talking about c++?
denisT.MaxDoctor
In a nutshell, you must specify the parent (owner) of the Qt dialog, which in our case is the MAX main window.
Ken_GordonQRB22
Yes, I forgot to mention, windows, C++, Qt, 3dsmax SDK 2024
and thanks, I already figured it out and found the error )
istan
See: GetQmaxMainWindow()
