How to get vertex normal using python
Message 1 of 21
I drag a box into an empty scene, then using the following python script to get vertex normal. However, the result is not what i expected.
From the output, we can see there are just two kind of normals, which is obviously wrong.
I know the face normal can be retrieved with Mesh.GetFaceNormal, but what I really want to get is the vertex normal taking smooth group into account(That means every vertex has three normals). I searched the python API docs, but can't find the right way to do that.
Can somebody help me?
  python script:
n=list(MaxPlus.Core.GetRootNode().Children)[0]
obj=n.EvalWorldState(0).Getobj()
tri_obj = MaxPlus.TriObject._CastFrom(obj.ConvertToType(MaxPlus.ClassIds.TriMeshGeometry, 0))
mesh=tri_obj.GetMesh()
for i in xrange(mesh.GetNumVertices()): print mesh.GetRenderedVertexNormal(i)
  output:
Point3(0, 0, -1.5708)
Point3(0, 0, 1.5708)
Replies (20)
Message 2 of 21
If i set three adjacent face have the same smooth group, then the shared vertex has only one normal.
In C++ SDK, I can get the right normal using RVertex. Is there something like that in Python.
Message 3 of 21
Swordslayer
Looks like neither Face::getAllVerts nor Mesh::getRVert are exposed in python. As a workaround, you can find the smoothing group borders and for verts that share two or more calculate the normals separately.
Message 4 of 21
Thanks for your reply.
Do you mean there is no way in python to get the internal rnormal of 3ds max, and we need to calculate the normals by ourselves?
Message 5 of 21
Swordslayer
Message 6 of 21
drew_avis
Hi there, here is an example of how to use this API:
An example of how to populate RNormals and get them with GetRenderedVertexNormals()
import MaxPlus
obj = MaxPlus.Factory.CreateGeomObject(MaxPlus.ClassIds.Box)
n = MaxPlus.Factory.CreateNode(obj, "myBox")
print "node name: %s" % n.Name
n.Convert(MaxPlus.ClassIds.TriMeshGeometry)
object_state = n.EvalWorldState()
obj_original = object_state.Getobj()
tri_obj = MaxPlus.TriObject._CastFrom(obj_original)
tri_mesh = tri_obj.GetMesh()
print "normals built? ", tri_mesh.GetNormalsBuilt() # will return 0 if normals are not yet built
tri_mesh.CheckNormals(True) # less expensive than BuildNormals(), because it will only build if normals
# do not yet exist
print "normals built? ", tri_mesh.GetNormalsBuilt() # will now return non-0 because CheckNormals() ensures
# we've built them
normal_count = tri_mesh.GetNormalCount()
vertex_count = tri_mesh.GetNumVertices()
print " normals: ", normal_count
print " verts: ", vertex_count
for i in range(0, vertex_count):
	print "vertex: " , tri_mesh.GetVertex(i)
	print "RNormal: ", tri_mesh.GetRenderedVertexNormal(i)
This is the script "demoGetRenderedNormals.py" under <3dsmax>\Scripts\Python\.
Drew
Drew Avis
Content Experience Designer
Message 7 of 21
drew_avis
import MaxPlus
# do not yet exist
# we've built them
Hope that helps,
Drew
Drew Avis
Message 8 of 21
RNormal:  Point3(0, 0, -1.5708)
RNormal:  Point3(0, 0, 1.5708)
RNormal:  Point3(0, -0, 1.5708)
RNormal:  Point3(-0, 0, 1.5708)
Thanks for your reply:)
Following your code, I still get the same result as above:(
By the way, I use 3ds max 2017, there is no "demoGetRenderedNormals.py" in the demo script directory.
Message 9 of 21
I guess you use 3ds max 2018, am I right?
Is your result correct? Can you post it here.
Thanks.
Message 10 of 21
drew_avis
EDIT: Ok, I re-read your first post, you want to take the smoothing group into account - let me look at this again and get back to you.
I get the same results:
vertex:  Point3(-12.5, -12.5, 0)
vertex:  Point3(12.5, -12.5, 0)
vertex:  Point3(-12.5, 12.5, 0)
vertex:  Point3(12.5, 12.5, 0)
vertex:  Point3(-12.5, -12.5, 25)
vertex:  Point3(12.5, -12.5, 25)
vertex:  Point3(-12.5, 12.5, 25)
vertex:  Point3(12.5, 12.5, 25)
Is this not what you're expecting?
I get the same thing in MAXScript:
b = box()
convertToMesh b
for v = 1 to b.numVerts do
	n = getNormal b v
	format "vertex: % normal: %\n" v n
-- result:
vertex: 1 normal: [0,0,-1.5708]
vertex: 2 normal: [0,0,-1.5708]
vertex: 3 normal: [0,0,-1.5708]
vertex: 4 normal: [0,0,-1.5708]
vertex: 5 normal: [0,0,1.5708]
vertex: 6 normal: [0,0,1.5708]
vertex: 7 normal: [0,0,1.5708]
vertex: 8 normal: [0,0,1.5708]
Drew Avis
Message 11 of 21
drew_avis
Ok, I just tested both the MAXScript and Python code on a box with all faces assigned to a smoothing group, and they appear to return the correct data.
mxs:
vertex: 1 normal: [0,-0.785398,-1.5708]
vertex: 2 normal: [0,-1.5708,-1.5708]
vertex: 3 normal: [0,1.5708,-1.5708]
vertex: 4 normal: [1.5708,0,-1.5708]
vertex: 5 normal: [0,-1.5708,1.5708]
vertex: 6 normal: [0,-0.785398,1.5708]
vertex: 7 normal: [0,0.785398,1.5708]
vertex: 8 normal: [0.785398,0,1.5708]
MaxPlus:
RNormal:  Point3(0, -0.785398, -1.5708)
RNormal:  Point3(0, -1.5708, -1.5708)
RNormal:  Point3(0, 1.5708, -1.5708)
RNormal:  Point3(1.5708, 0, -1.5708)
RNormal:  Point3(0, -1.5708, 1.5708)
RNormal:  Point3(0, -0.785398, 1.5708)
RNormal:  Point3(0, 0.785398, 1.5708)
RNormal:  Point3(0.785398, 0, 1.5708)
This is 2018.
Drew
Drew Avis
Message 12 of 21
That's not correct.  There are just two different normal(positive z, negative z) for the 8 vertex.
Message 13 of 21
drew_avis
EDIT: Ok, I think I understand now, sorry for the confusion - you want the 3 normals shown in your original diagram because the faces are not in the same smoothing group.  It doesn't look like GetRenderedVertexNormals() returns more than the first vertex normal.
Drew
Drew Avis
Message 14 of 21
Yes. So do you think i have to calculate normals by ourselves in python? I am just wondering whether there is an API
can do that.
Message 15 of 21
drew_avis
Right now you will need to calculate normals yourself, if there's more than 1 normal per vertex.  Thank you for posting this - I've opened a defect on this lack of exposure, though if it does get fixed, it won't be until after the 2019 release.
Drew
Drew Avis
Message 16 of 21
Got it. Thanks
Message 17 of 21
denisT.MaxDoctor
Drew
what do mean by "calculate"? average? but it doesn't make sense. Every geometry vertex (by index) might have more than one corresponding RNormal. It's how it is. And you have to live with it...
i don't see any bug in code above. I just don't sure that
does do everything right
Message 18 of 21
Yeah, but the problem is that we can't access the rnormal with Python API (GetRenderedVertexNormal fails to do that).
With C++ API, we can.
Message 19 of 21
denisT.MaxDoctor
there is no this method in c++ api.
you can get pointer to the 'i-th' RVertex with mesh->getRVertPtr(int i)
after that you have access to RNormal(s). This is all that you need
Message 20 of 21
I think you misunderstood me. Sorry for the confusion.
1. Of course I know there is no 'GetRenderedVertexNormal' in C++. The problem is that in Python, its result is wrong.
2. "With C++ API, we can", I mean in C++ we can get the right rnormal using RVertex like what you stated.
