Announcements
How to execute a script on loading a scene?
I made a little script that switches fog on/off depending on the z position of a camera. (A greenish fog is switched on when the camera goes below sea level...)
callbacks.addScript #preRenderEval "mlbSwitchUnderwater()" id:#mlbUW
fn mlbSwitchunderwater =
mlbCamera = $Camera04
mlbFog = getAtmospheric(1)
if mlbCamera.position.z > 0 then
setactive mlbFog false
else
setactive mlbFog true
However i keep forgetting to run the script when I load the scene. So I rendered an animation and it turns out the fog didn't do its thing.
Is there a way to embed a script in a scene, so it is executed when the scene is loaded??
MLB
Have you tried this callback?
#filePostOpen:
I've used the following to add a popup when a file is loaded
clbckExecSTR = "messageBox \""+ message_body + "\" title:\"" + message_title + "\""
callbacks.addScript #filePostOpen clbckExecSTR id:#onload_message persistent:true
Hope this helps.
I tried it. Like so:
callbacks.addScript #filePostOpen "mlbUnderwater()" id:#mlbUW persistent:true
fn mlbUnderwater =
callbacks.addScript #preRenderEval "mlbSwitchUnderwater()" id:#mlbSUW
else
now it tries to execute something when i open the file, but i get this error message:
-- Error occurred in anonymous codeblock
-- Frame:
-- mlbUnderwater: undefined
>> MAXScript Callback script Exception: -- Type error: Call needs function or class, got: undefined <<
-- called in anonymous codeblock
-- Frame:
-- Frame:
Any ideas?
MLB
Now whenever i open the file it tries to execute something. How do I remove the code from the file?
MLB
To remove your script from a file, use
callbacks.removeScripts #filePostOpen id:#mlbSUW
callbacks.removeScripts #preRenderEval id:#mlbSUW
I am looking at your problem, but haven't figured out why it's not working yet (might have to wait for my coffee break, have meetings this afternoon)
EDIT: not sure if the above is correct, but it's callbacks.removescripts that you need to look at in the help for the exact syntax.
EDIT2: There is a box for scripts to be run before rendering in the render rollout, don't know it that's suitable for your code for this one.
Thanks!
I managed to remove the scripts following your suggestion.
Also your sugggestion to use the render rollout works fine!
MLB
Yay! glad it all worked out (and also glad I don't have to fix your script, I hate callbacks, I always manage to make a mess of it)
