How to exclude instances from a selection?
04:22 PM
- Mute
- Permalink
- Report
Need some help...
I have a whole heap of objects (some instances) and want to create a new array of all the objects except the instances.
This is my attempt, but can't get it to work?
ss = getCurrentSelection()
newSS = #() -- the new array
append newSS ss --put the first object in it
for i = 2 to ss.count do -- go through all the object I have selected
thecurrentNode = ss -- the selected node
for j = 1 to newSS.count do -- go through the new array
theArrayNode = newSS-- get the object from the new array
if (areNodesInstances thecurrentNode theArrayNode) == false then -- check if the selected node is an instance of the new array node
if (finditem newSS thecurrentNode) == 0 then -- check that selected node isn't already in the array
append newSS thecurrentNode -- add the selected node to the new array
print ("not instance = " + thecurrentNode.name)
