How to declare a function in MaxScript
YASUSHI_EMOTO
YASUSHI_EMOTO
I have created the following simple code
When I run this, I get an error.
Since the testB function is defined before the testA function, the testA function cannot be called inside the testB function. Is there a solution to these problems?
fn testB =
      testA()
fn testA =
      messagebox "test!" title:"OK"
testB()
The error message is as follows
-- Error occurred in anonymous codeblock; filename: ; position: 25; line: 3
-- Type error: Call needs function or class, got: undefined
-- MAXScript callstack:
--	thread data: threadID:35944
--	[stack level: 0]
--	In testB(); filename: ; position: 26; line: 3
--		Locals:
--			testA: undefined
--		Externals:
--			owner: undefined
--	[stack level: 1]
--	called from top-level
denisT.MaxDoctor
there are several ways to do it in MXS...
the most used are:
--1:
	local functionB
	fn functionA = (functionB())
	fn functionB = (print #A)
	functionA()
--2:
	struct structFN
		fn functionA = (this.functionB()),
		fn functionB = (print #AA)
	str = structFN()
	str.functionA()
of course the same technique can be used in #global scope too:
global print_val
fn print_a =
	print_val #a
fn print_val val = (print val)
print_a() ​
but you should be aware that defining custom functions or methods in the global scope is not good practice and should be avoided whenever possible.
