How to customize menubar colors
Menubars in all popup windows as usual have light-gray gradient fill even if dark color scheme is active. Is there the way to create/customize one that looks like main 3dsmax menubar (dark background, white labels)?
I have figured it. However in this case menu should not be created with 3ds Max API.  But with CMFCMenuBar and the window should be CFrameWnd in the case if you use c++.
