How to animate points of a Spline Shape Object?
08:02 AM
- Mute
- Permalink
- Report
Hi there,
I try to do something which is really easy using the interface but quite not so obvious for me inside a plug-in... Well the point is to import animated splines from an XML file where all control points are stored for each curve and each frame (this is a hair simulation computed with a standalone mechanical solver)
My question is how can I have access to vertices to assign them a XYZ Point3 controller (then assigning a float expression controller to X, Y and Z, filled with keyframes read from the file)?
Any help will be more than appreciated!
LBx
LBx
