how to align pivot axis to world?
Waseem_Dabbas
Waseem_Dabbas
I want to make a code that aligns the pivot point axis of a selected object/s, or group/s, to the world like the following video
istan
Waseem_Dabbas
Thank you for answering, I have this simple code that moves the pivot of a selected object/s to the min of the Z axis,
for i in selection do (i.pivot = [i.center.x, i.center.y, i.min.z])
so to do what I asked before, I added this line,
WorldAlignPivot <node>
but didn't know what to put in the node, I apologize for not knowing coding, but I just wanted to add this line if possible.
Thank you
istan
Sry, I don't understand your question. Don't you know what a node is? Just replace <node> with your node you want to align.
Waseem_Dabbas
It works!
As I said, I don't have information about coding. Later, I found out that I need to do the following for the program to work properly.
        WorldAlignPivot i
I asked the same question a while ago, but I didn't receive the same level of help. I appreciate your cooperation
