How to access verticles or faces in a object
Hello everybody,
i'm a C/C++ developer and a newbie on 3DS max programming.
I'm writing a sample plugin for 3Ds max 2014.
I want to access to verts or faces of a scence object to calculate bound rect of them.
I know, i can access them through a mesh of the object if the object is TriObject or SimpleObject base.
I don't know how to do that for another scence object.
For any ideas I would be grateful.
To get render mesh:
const ObjectState& obj = inode->EvalWorldState(time);
tempMesh = ((GeomObject*)obj.obj)->GetRenderMesh(time, inode, view, needDelete);
or to get a display mesh:
TriObject* Utils::GetTriObjectFromNode(INode *node, bool& deleteIt, const TimeValue time) {
    deleteIt = false;
    ::Object *obj = node->EvalWorldState(time).obj;
    if (obj->CanConvertToType(Class_ID(TRIOBJ_CLASS_ID, 0))) {
        TriObject *tri = (TriObject *) obj->ConvertToType(time, Class_ID(TRIOBJ_CLASS_ID, 0));
        // Note that the TriObject should only be deleted
        // if the pointer to it is not equal to the object
        // pointer that called ConvertToType()
        if (obj != tri) {
            deleteIt = true;
        return tri;
    } else {
        return NULL;
PS: are you aware of Object::GetWorldBoundBox()?
Thanks alot for your detailed guidance.
Because i not only calculate the bound rect of the object but also get bound rect of selected faces or vertices of the object.
i will try to get selected faces using your suggestion.
Like : tempMesh->FaceSel() or triObj.mesh.FaceSel().
if there is any better way, please show me!
