How do I Select and Delete duplicate line segments...
I have a complex Editable Spline that I created from an Edit Poly using the Create Shape command... the Editable Spline has many duplicate line segments that are causing me problems...
Is there a method for Selecting and Deleting duplicate line segments from an Editable Spline...
Thanks for your help...
Jim
you could loop through all the spline segements and compare the start and end points and if they are the same delete that segment.
