Announcements
help with fn using execute
hi there
i have done a script to get back the modifiers for all objects selected & assign values to the properties of it so i just have a problem with this fn the fn should return array with all modifiers properties & another array with the index of the bool values properties
fn Modname sel =
if (sel == undefined) then (messagebox "plz select objects & press again"
else(
global allmod = #()
global modprops = #()
global bool_index = #()
for obje in sel do
for m in obje.modifiers do
allmodbefore = allmod.count
if ((findstring m.name " " )!= undefined ) do
b = filterString m.name " "
nametmp = ""
for i = 1 to b.count do nametmp += b
m.name = nametmp
appendIfUnique allmod m.name
if allmod.count != allmodbefore do(
modprop = getPropNames obje.modifiers
modpropf = #()
indv_boolindex = #()
for pro in modprop do
a = obje.modifiers
st = "a."+(pro as string)
pr_val = execute (st )
try(
if (pr_val == true or pr_val == false)do(
append modpropf pro
append indv_boolindex modpropf.count
(pr_val as float )
append modpropf pro
)catch ()
append modprops modpropf
append bool_index indv_boolindex
return bool_index
return modprops
return allmod
when i run the fn frist time when i open the max i get an error in
-- Frame:
-- pr_val: undefined
-- st: "a.BendAngle"
-- a: Bend:Bend
but run the fn again it works fine
why ?
--change this...
--to...
st = "$"+obje.name+"."+a.name+"."+(pro as string)
thank u
worked very fine
thanx
