Google Drive File Stream Pathname Problem
lathander
lathander
My organization is using google suite's cloud service: drive file stream. I have many 3dsmax scripts and I am tired of carrying and transfering them onto other computers all the time. So what I am trying to do is setup a cloud script folder for it so I can call them with the same pathname in macros.
Google Drive File Stream is a basic tool. It creates a virtual drive first, then creates 2 folders in it. Named "my drive" and "team drive". You can change the letter of the virtual drive . So I made it S:\ . Yet it doesnt allow you to rename the main folders. Attached is how it looks.
Here is my problem.  I am  located in Turkey. So google suite's interface is Turkish.
In the virtual drive , my main folder that can't be renamed is "Drive'ım"  which means "my drive" in Turkish.
Since it has one non-mainstream letter and an apostrophe , when used in macros, it returns with errors.
Here is a sample macro , I generally use:
macroScript imageplane
category:"lathander"
toolTip:"imageplane"
on execute do
fileIn ("S:\Drive'ım\Scripts\MS\dragNDropReferences11.ms")
this returns errors because of that folder's name.
I wonder if anyone knows how to work around this problem.
Thank you.
Swordslayer
Unless you're stuck with an old version of 3ds max, it should work (and definitely works with accented letters and whatnot here - well, unless I save the macro as non-UTF8 file but that's a given). Does going through getOpenFileName() give you the same path? Alternatively, you could use symbolic links instead (Link Shell Extension makes working with them extremely easy).
lathander
Symbolic links works like a charm.Cat Happy Why havent I thought of it ?
Well thank you. You saved a week of mine at the least, if not a whole month.
PS: getOpenFileName() didnt work. I have no idea what the glitch is. I am on max 2013.
