getOpenFileName default path only if no prior history
Hi all !
I was wondering if there is a way to set a default path only if it's the first time the user use the dialog and use the last path the other times.
I know I can set a filename with just the path but it's a bit overwhelming to always start from the default path and use the history to get to the last used path.
Thanks !
Write the last used path out to an ini file, using setinisetting, try() and load via getinisetting , and if that fails, use the default path
Ah right thanks ! But I ended writing it in the registery, and ini file would probably have been cleaner thought!
