Get number of elements in a mesh object
Message 1 of 19
Is there a way to look at a mesh object and find out how many elements are contained within? I know I can access elements by using face bit arrays but was hoping there would be an easier way that does not involve having to do it this protracted way. I was hoping there may be a <mesh>.getNumElements that I can access, but I have not found such an attribute. I probably missed it.
Replies (18)
Message 2 of 19
Swordslayer
Message 3 of 19
Ah buggar. Oh well, thanks for the link, I am sure it will prove very useful.
Seems like it would be a worthwhile addition to the MeshOps or PolyOps interface though.
Message 4 of 19
bigonethegod
Made this tiny modifier just for this!
https://gumroad.com/l/elements_count
Message 5 of 19
bigonethegod
Mesh Elements Count
Message 6 of 19
obaida_ds
sorry , the function was not working so I deleted it .
Message 7 of 19
denisT.MaxDoctor
Please test your solutions before posting them...
try:
delete objects
gc()
s = geosphere name:#test_mesh segs:4 wirecolor:orange isselected:on
converttomesh s
meshop.explodefaces s #all 0
GetMeshElements s
Message 8 of 19
obaida_ds
Thanks for Feedback , ofc it should not be the best way but it works !! (not yet , need more tests)
Message 9 of 19
denisT.MaxDoctor
better now. at least it somehow works 🙂 ... but it gives wrong number
Message 10 of 19
obaida_ds
🙂 , actually I tested it on copied faces (not detached) so it works , detached faces keep its index !! .
Message 11 of 19
obaida_ds
fn GetMeshElements obj = (
	local tf = obj.faces as bitarray,
	el = meshOp.getElementsUsingFace obj 1, n = 1
	if el.numberset != obj.numfaces do (
		local lf = tf - el
		while lf.numberset != 0 do (
		       lf -= meshOp.getElementsUsingFace obj (lf as array)[1]
			n += 1
	n
I Hope this one will work 🙂
Message 12 of 19
denisT.MaxDoctor
Great! Now let's test the performance... 😉
change the number of geosphere segment to 20 first....
delete objects
gc()
s = geosphere name:#test_mesh segs:20 wirecolor:orange isselected:on
	converttomesh s
	t0 = timestamp()
	h0 = heapfree
	n = GetMeshElements s
	format "num:% time:% heap:%\n" n (timestamp() - t0) (h0 - heapfree)
Message 13 of 19
obaida_ds
ok , not that much 🙂  ,
if you can help here we all will appreciate that 🙂
Message 14 of 19
denisT.MaxDoctor
for reference:
* the method shown by Swordslayer above takes ~30 ms
* another method (that you can find on CGTalk) takes ~10 ms
Message 15 of 19
obaida_ds
thank .
Message 16 of 19
denisT.MaxDoctor
@obaida_ds wrote:
thank .
Anyway you are on the right track. The best practical solution is to first try to do it yourself, then find the highest rated and find out how yours differs from the best.
There was a big discussion on CGTalk about optimizing the search for mesh elements ... as a result of testing and discussion, the decision took the final form. Unfortunately, CGTalk is now broken by "fatal improvements". And even I can not find this topic, although I was a direct participant in it. Maybe someone will be lucky to find it somehow.
Message 17 of 19
Serejah
@denisT.MaxDoctor  написал (-а):
@obaida_ds wrote:
thank .
All I remember is this topic about poly elements count.
A faster method for retrieving element count
Message 18 of 19
obaida_ds
Message 19 of 19
denisT.MaxDoctor
How to quickly eliminate elements with lowest face count?
yes... those are the discussions I was talking about. Thanks guys for finding it!
