Announcements
Function returning incorrect slider ranges
AndyVanDalsem
AndyVanDalsem
I'm trying to write a function to return Custom Attribute values, in this case the range of the sliders in the Attribute's Rollout.
The way it's written now the function returns the correct range if only one object is selected: [0,100,0]
But if multiple objects are selected it starts returning ranges of [0,0,0]
Can anyone tell me why this is happening and where I went wrong?
Here's the script and I'm attaching a sample scene.
fn print_Att_Info =
	for i in selection where i.modifiers.count > 0 do
		for j in i.modifiers do
			if classOf j == emptyModifier do
				def = custAttributes.getDefs j
				for d in def do
					rolloutName = (custAttributes.getPBlockDefs d)[1][4][2]
					rolloutDef = (getProperty j.CustAttributes[d.name] rolloutName)
					for c in rolloutDef.controls do
						if isProperty c "range" do
							format "obj:%\n ctrl:%\n range:%\n " i.name c.caption c.range
 Thanks for any help!
denisT.MaxDoctor
ems = getclassinstances EmptyModifier
for em in ems do
	modpanel.setcurrentobject em
	for k=1 to em.custattributes.count do
		ca = em.custattributes[k]
		--def = custattributes.getdef ca
		--ss = custattributes.getdefsource def
		--format "-------------------------------\n%\n--------------------------------\n" ss
		for c in ca.Custom_Attributes.controls where iskindof c SliderControl do format "%\n" c.range
as you can see from this snippet, the slider range value is only valid for 'get' after it has been created once ...
you use the same CA everywhere, so you have to define its attribID (it makes sure you are using an instance of the same CA definition). In this case, only one instance needs to be created to have the correct range for all others.
