Command line "3dsmax.exe -mxs" not working with "fileIn" command
Hi Guys,
Can anyone help me with the following problem:
I am making a Python program that can open Max files and perform different kinds of action on them.
I am using the command line to start 3ds Max and I would like to pass custom variables to 3ds Max. The new 3dsmaxbatch.exe worked fine, however, from time to time some of the files became unresponsive and it made the program unstable. So I decided to rather use "3dsmax.exe -batch" because in that case, I can get the Windows process ID of each 3ds Max instances and close them later if they freeze.
I tried to use the "-msx" switch to pass the variables and run a script after with the "fileIn" command. If I use the "fileIn" command, the file is not opening. It seems that it only doesn't work with "fileIn", because if I delete it I can use other commands after -mxs.
Currently, I'm using the following code to start 3ds Max from Python:
\"C:\\Program Files\\Autodesk\\3ds Max 2021\\3dsmax.exe\" -batch -silent -ms -mxs \"fileIn \"S:\\*** location of the max script ***\\test.ms\"\" \"M:\\*** location of the max file ***\\maxfile.max\"
Does anybody have any idea why it doesn't work with "fileIn" while it works with other commands?
Thank you!
