Announcements
Exporting a file using a command in cmd
I want to use 3dsMax 2015 inside a batch file.
I've got a script that imports a file into Max. This file contains 20 or 30 different model parts and now I need to export the whole model as one file, preferably .obj or .dae, unlike BatchImporterExporter that exports all parts as seperate files.
How will I do this in a command line?
Thanks in advance.
I suppose you could add export to the end of import script.
Also if it's needed you can simply merge all objects with a script before export.
