Error while trying to package project for Android
Hello everyone,
I'm writing here because I need your help with Autodesk 3ds Max Interactive.
Indeed, when I try to use the deployer to package my project for Android, I get this error :
Editor / General: Android Packager: Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\Audrey\AppData\Local\Temp\APKTOOL6937764462712938532.tmp, -0, arsc, -0, arsc, -I, C:\Users\Audrey\AppData\Local\apktool\framework\1.apk, -S, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\res, -M, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\AndroidManifest.xml]
    at brut.androlib.Androlib.buildResourcesFull(Androlib.java:478)
    at brut.androlib.Androlib.buildResources(Androlib.java:412)
    at brut.androlib.Androlib.build(Androlib.java:311)
    at brut.androlib.Androlib.build(Androlib.java:264)
    at brut.apktool.Main.cmdBuild(Main.java:227)
    at brut.apktool.Main.main(Main.java:84)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\Audrey\AppData\Local\Temp\APKTOOL6937764462712938532.tmp, -0, arsc, -0, arsc, -I, C:\Users\Audrey\AppData\Local\apktool\framework\1.apk, -S, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\res, -M, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\AndroidManifest.xml]
    at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:439)
    at brut.androlib.Androlib.buildResourcesFull(Androlib.java:464)
    ... 5 more
Caused by: brut.common.BrutException: could not exec: [aapt, p, --forced-package-id, 127, --min-sdk-version, 21, --target-sdk-version, 25, --version-code, 1, --version-name, 1.0, -F, C:\Users\Audrey\AppData\Local\Temp\APKTOOL6937764462712938532.tmp, -0, arsc, -0, arsc, -I, C:\Users\Audrey\AppData\Local\apktool\framework\1.apk, -S, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\res, -M, C:\Users\Audrey\AppData\Local\Temp\tmpD3A5.tmp\deploy\AndroidManifest.xml]
    at brut.util.OS.exec(OS.java:97)
    at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:433)
    ... 6 more
Caused by: java.io.IOException: Cannot run program "aapt": CreateProcess error=2, Le fichier spÚcifiÚ est introuvable
    at java.base\java.lang.ProcessBuilder.start(ProcessBuilder.java:1128)
    at java.base\java.lang.ProcessBuilder.start(ProcessBuilder.java:1071)
    at brut.util.OS.exec(OS.java:90)
    ... 7 more
Caused by: java.io.IOException: CreateProcess error=2, Le fichier spÚcifiÚ est introuvable
    at java.base\java.lang.ProcessImpl.create(Native Method)
    at java.base\java.lang.ProcessImpl.(ProcessImpl.java:420)
    at java.base\java.lang.ProcessImpl.start(ProcessImpl.java:151)
    at java.base\java.lang.ProcessBuilder.start(ProcessBuilder.java:1107)
    ... 9 more
Do you know how I could fix this? I followed all those steps :
help.autodesk.com/view/Stingray/ENU/?guid=__stingray_help_getting_started_get_started_android_html
But I still get this error.
Also it's the first time I'm using 3DS Max Interactive, I work on Revit usually but I'm trying to export my construction in Revit to 3DS Max Interactive to see it in VR.
Thank you for your help!
__ben__
As an initial troubleshooting step, could you please try the deployment process on one of the sample apps (like basic_project) that come with Max Interactive? That will provide insight as to whether this is an issue with Stingray, an environment issue or something specific to your content.
Ben
Thank you for your answer, I tried with basic project but I still got the same error.
