Error in pymxsExtend.py Undo
morten_bohne
morten_bohne
in 3ds Max 2017, there is a bug in pymxs undo:
It is caused by a typo in pymxsExtend.py in the undo implementation (it looks for a 'lable' variable instead of the 'lavel'-kwarg supplied)
Changing this seems to fix the problem, but it would be nice if it just worked in future versions
Sorry to report the bug here, but the "Speak back -> Report a Problem..." in max seems to be broken
drew_avis
Hi, thanks for reporting this.  I can confirm that it's a known bug and has been fixed in 2018.
Regarding the bug report link, what is not working for you?  For me, the Speak Back > Report A Problem takes me to:
http://download.autodesk.com/us/support/report_a_bug.html?SelProduct=3dsMax
and I'm able to submit a report.
Do you not get that?  Or is the submit button not working for you?
Drew
Drew Avis
Content Experience Designer
morten_bohne
thanks for the quick reply. Still can't get to the bug-reporting site, but it might be because of the firewall i'm behind at work. i'll ask our it dept to look into that 🙂
