Announcements
Empty Category in the User Interface
huiblinden
Observer Observer
huiblinden
Observer
Observer
For some reason we experience an empty Category in the User Interface Window. It also seem to contain invisible items.
Is there a way to find out where this is coming from and remove this Category.
We use " useUserProfiles=0" so removing the enu folder is not possible.
Any suggestions would be most helpful
Swordslayer
Interesting, never seen that happen. You might try running macros.list() in the maxscript listener to see if there are any empty or space-filled (or maybe unsupported character) category and item names (it also shows the path to the macroscripts so you can then remove/edit those).
I've actually encountered this as well. I have no idea what is causing it. I checked all the currently registered macros and they all check out.
PiXeL_MoNKeY
So looks like Mitchell and I tracked it down to the Itoo Software plugins. They joy of tracking it down.
  1. No "Edit Macroscript" open so probably a plugin function publishing item and not a Macroscript.
  2. Add Button to a new Toolbar and Save Toolbar file.
  3. Check Toolbar file for entry and found:
  4. <Item typeID="2" type="CTB_MACROBUTTON" width="8" height="0" controlID="0" macroTypeID="3" macroType="MB_TYPE_ACTION" actionTableID="1840288899" imageID="-1" imageName="" actionID="-1253074912" tip="" label="" />
  5. Run the code below:
  6. actArr = for val in 1 to actionMan.numActionTables where (actionMan.getActionTable val).id == 1840288899 collect val
    for val2 in actArr do (
    	actTbl = actionMan.getActionTable val2
    	format "ActionTable:\nID: %\nName: %\nContextID: %\nContextName: %\nNumActions: %\n" actTbl.id actTbl.name actTbl.contextID actTbl.contextName actTbl.numActionItems
  7. Output:
  8. ActionTable:
    ContextID: 0
    ContextName: Main UI
    NumActions: 16
Removing plugins validated it was RailClone and Forest Pack Pro.
Hope that helps,
-Eric
huiblinden
Observer
Observer
Great work, some smart research !
I get the same result when I run your code. Time to contact Itoo Software about this 🙂
