Edittext - needs function or class
I've got a simpleUI here that passes a string from a edit text box to a function.
-- put everything in brackets
	local printIt
	rollout moveItRollout "" width:230 height:70
		label lbl1 "Enter secret code" pos:[10,10] width:200 height:20
		editText edStr "" pos:[10,40] width:160 height:20
		button btnOK "Okay" pos:[180,40] width:40 height:20
		on btnOK pressed do
			myString = edStr.text as string
			printIt myString
		function printIt str =
			print str
	) -- end rollout
	createDialog MoveItRollout "" width:230 height:70
Only it keeps  the error : >> MAXScript Rollout Handler Exception: -- Type error: Call needs function or class, got: undefined
I don't know why? Any pointers please?
To get around this I've removed the function and but that part of the code within the on button pressed segment.
Steve_Curley
Probably the order in which things are delared as there's a fairly specific order when dealing with rollouts. This Maxscript help page should give you some clues.
http://help.autodesk.com/view/3DSMAX/2015/ENU/?guid=__files_GUID_608825CD_D025_4054_91E2_2562A6AB31C...
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
blakestone
This line is invalid:
printIt myString
It should be:
print myString
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Steve_Curley
He's trying to call the printIt function just below passing myString as a parameter - that function has a print statement in it to do the actual printing.
As per the help page I linked, functions should come before event handlers which is what's causing the error (probably - I've not actually tested the code).
Max 2016 (SP1/EXT1)
blakestone
ah of course. yes as you've suggested if you move the PrintIt function above the button pressed then it will work.
Thanks for that. That's a good reference page as well, which I've managed to overlook because I was searching for "scope" and not "visibility" - which is for object paramaters and Wonder Woman's plane,  that sort of thing.
Steve_Curley
Not the snappiest title for page I would have to agree, but definitely one to remember 😉
Max 2016 (SP1/EXT1)
