dummy on the line
dummy on the line
dummy on the line
yoldashlar ; urgent is there any way to driving the dummy on the path constant whit another object (link to another object our other line) whit max scripts.
denisT.MaxDoctor
As you can see, no one answers your question. There are reasons for this ...
Try to describe the problem in more detail, ask the same question, but in a different way, provide a picture that will help us understand the subject and the problem.
Here's how it all works. And this is something that can help you ... unless, of course, you really need this help.
istan
Honstly, I still do not understand!
there are 6 arrows in the image. which arrow shall do what an when? Why is it not possible you simply link them together (parent/child)? Why dont you add a detailed description about the task you want to solve?
denisT.MaxDoctor
Probably it's not really needed... I have no other explanation.
istan
Well, this is also imho the only remaining explanation.. on the other hand, is the question even related to "programming"?
Untitled picture.pngmaybe I couldn't explain it good the dummy has path constraint on the circle how I can drive it whit line our the dummy always should be at the intersection of the tow line collision?
